toby311
#1 Posted : Thursday, February 11, 2010 1:23:05 PM(UTC)
toby311
have no heat but got shock when i touched the heater coil so there is power there but is it a faulty heater or can it be the thermostate ?
toby311
#2 Posted : Thursday, February 11, 2010 1:24:36 PM(UTC)
toby311
cuz i dont want too replace more than neccasary on it
#3 Posted : Thursday, February 11, 2010 4:16:38 PM(UTC)
[COLOR="Blue"]have no heat but got shock when i touched the heater coil so there is power there but is it a faulty heater or can it be the thermostate ?[/COLOR]
Do not mess with the unit plugged in unless you know what you are doing.
Depending where the timer is set there is always 120 volts on the heater. It uses the full 240 volts.
NOTE: 240 volts is lethal, even 120 can take you out if you have a bad heart.
Replacement parts for FRIGIDAIRE GCER1042FS0 Frigidaire/dryer | AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134067000.pdf
I am assuming that the motor runs OK.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
[COLOR="Red"]Be very careful when doing the above troubleshooting.[/COLOR]
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 13 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
Fridgidaire range circuit board fire (Oven Repair (including Ranges and Cooktops))
by ron3033 1/22/2024 6:06:11 AM(UTC)
fridgidaire control board is dim (Oven Repair (including Ranges and Cooktops))
by Guest 9/13/2022 10:28:00 AM(UTC)
fRIDGIDAIRE AFFINITY FRONT LOAD WASHER WILL NOT STAY IN LOCK MODE (Washer Repair)
by Guest 2/21/2022 3:21:13 PM(UTC)
Fridgidaire Professional side by side coca 2008 (Refrigerator & Freezer Repair)
by Guest 5/8/2021 8:32:36 PM(UTC)
Fridgidaire FDPC4221AW0A (Dishwasher Repair)
by Guest 3/20/2021 4:05:23 PM(UTC)
FIXED: Fridgidaire FFLE3911QW (Washer Repair)
by liviekins 2/23/2021 7:53:27 AM(UTC)
Fridgidaire Side by Side lfss2612tp Not Cooling (Refrigerator & Freezer Repair)
by HotDangit! 12/21/2020 1:52:53 PM(UTC)
Fridgidaire Ice Maker Auger Motor Won't Stop Running (Refrigerator & Freezer Repair)
by ehmjay 8/18/2020 5:35:03 AM(UTC)
Fridgidaire defrost cycle (Refrigerator & Freezer Repair)
by samv 6/23/2020 4:57:32 PM(UTC)
Defrost cycle-Fridgidaire mod FPUH19D7LF1 upright freezer (Dishwasher Repair)
by samv 6/23/2020 1:02:25 PM(UTC)
Fridgidaire microwave - works - no heat (Microwave Repair)
by jamesfarrell 9/10/2019 1:09:43 PM(UTC)
Fridgidaire Ice maker Not defrosting (Refrigerator & Freezer Repair)
by D_Spin 4/30/2019 2:04:28 PM(UTC)
Fridgidaire electric stove (Oven Repair (including Ranges and Cooktops))
by NAPCO4WD 1/5/2019 8:08:46 AM(UTC)
Fridgidaire Range Error code F10. (Oven Repair (including Ranges and Cooktops))
by 22pistol 3/2/2017 5:18:33 PM(UTC)
Leaky door fridgidaire dishwasher (Dishwasher Repair)
by DrColorado 10/25/2016 5:50:57 AM(UTC)
