Rank:: Member
I'm not as familiar with this model where everything was accessible from the back. it looks to me like the fron comes off i just want to be sure before i embarass with my neighbor. thank you herman
this model for heater +thermostat is accessable from back ,if this is an older model over 10 years ,you would have to lift top to remove heater assembly to remove heater if it is the problem
Rank:: Member
Originally Posted by: herman I'm not as familiar with this model where everything was accessible from the back. it looks to me like the fron comes off i just want to be sure before i embarass with my neighbor. thank you herman when I removed the bottom access panel i could see the heater shroud and a couple of thermostats and the blower assy do i still have to go through the back, and also is there a fuse? thank you herman
