wishmaster22
#1 Posted : 17 years ago
wishmaster22
Hi, I am hoping someone can help me fix this drain problem on my dishwasher. It started out not draining all of the water out.
After looking inside I found bits of paper from a label (possibly) from a container. I then took off the lower arm and checked for any debris. Nothing found. So then I took a screwdriver with a star tip and removed the plastic ring with about 10 or so screws. Inside was an impeller of sorts and no debris was found. I replaced the plastic piece and made sure the gasket was in place... It seemed okay. So then I tried it and still it would not drain completely. So then I took off the hose and unscrewed the check valve. I ran water thru it from both sides. It drained good from one side and held water on the other side( the side where the hose attaches). I tried blowing thru the hose and it seemed a little plugged. I then ran a fish tape thru it and blew in it again, this time it seemed okay. SO I attached everything and let it fill a little, and then hit the drain button, and it won't drain at all. :confused:
So what could be the problem???:mad:
I would appreciate any help on this .:)
misterfixall
#2 Posted : 17 years ago
misterfixall
Have You Removed Drain Hose Under Sink +push A Screw Driver Through Drain Pipe?
whirlpool won't drain on the first rinse (Washer Repair)
by dyvnflyboy 10 years ago
whirlpool won't drain on some settings (Dishwasher Repair)
by fitzpd 12 years ago
whirlpool won't drain (Washer Repair)
by banginglc1 14 years ago
Whirlpool won't drain or spin (Washer Repair)
by csledzik 14 years ago
whirlpool won't drain/spin (Washer Repair)
by joshcarguy 15 years ago
Whirlpool won't drain, then spins VERY slow (Washer Repair)
by nswaibel 15 years ago
