wishmaster22
#1 Posted : Tuesday, April 29, 2008 4:42:19 PM(UTC)
wishmaster22
Hi, I am hoping someone can help me fix this drain problem on my dishwasher. It started out not draining all of the water out.
After looking inside I found bits of paper from a label (possibly) from a container. I then took off the lower arm and checked for any debris. Nothing found. So then I took a screwdriver with a star tip and removed the plastic ring with about 10 or so screws. Inside was an impeller of sorts and no debris was found. I replaced the plastic piece and made sure the gasket was in place... It seemed okay. So then I tried it and still it would not drain completely. So then I took off the hose and unscrewed the check valve. I ran water thru it from both sides. It drained good from one side and held water on the other side( the side where the hose attaches). I tried blowing thru the hose and it seemed a little plugged. I then ran a fish tape thru it and blew in it again, this time it seemed okay. SO I attached everything and let it fill a little, and then hit the drain button, and it won't drain at all. :confused:
So what could be the problem???:mad:
I would appreciate any help on this .:)
misterfixall
#2 Posted : Tuesday, April 29, 2008 5:48:08 PM(UTC)
misterfixall
Have You Removed Drain Hose Under Sink +push A Screw Driver Through Drain Pipe?
whirlpool won't drain on the first rinse (Washer Repair)
by dyvnflyboy 8/19/2015 6:28:50 PM(UTC)
whirlpool won't drain on some settings (Dishwasher Repair)
by fitzpd 5/28/2013 6:36:42 AM(UTC)
whirlpool won't drain (Washer Repair)
by banginglc1 2/17/2011 3:21:16 PM(UTC)
Whirlpool won't drain or spin (Washer Repair)
by csledzik 9/28/2010 6:11:51 PM(UTC)
whirlpool won't drain/spin (Washer Repair)
by joshcarguy 1/30/2010 3:00:46 PM(UTC)
Whirlpool won't drain, then spins VERY slow (Washer Repair)
by nswaibel 11/6/2009 8:24:58 AM(UTC)
