Dryer will not start when dial is pushed in. All I get is a buzzing noise. Have tried different settings but not working.
you will need 2 people to do this but have one person hold down the start button at the same time as the other person opening the dryer door and holding down the door switch and then the second person needs to manually turn the dryer drum (all of that has to be done at the same time) and if the dryer starts up then you have a bad motor
