The dryer motor keeps shutting off but the motor does not get hot.If I turn the dryer drum by hand a couple turns it will restart but shut off agin in a few min.Could built up dust or lint in or arond the motor cause this?
Rank:: Advanced Member
possible. sounds as if motor is failing. also clean out duct hose from back of dryer to out side,
