Nater07
#1 Posted : Tuesday, February 2, 2010 2:12:11 PM(UTC)
Nater07
Ok the dishwasher seemes to run fine thru all the cycles.... but after it doesn't drain. leaves about 2" water in the bottom. We just bought it off craigslist and got it installed. What do yall think it might be? We leave about 3-4 cups of water start a cycle and stop real quick seems to start to drain but then water just comes back up the drain.
#2 Posted : Tuesday, February 2, 2010 11:57:11 PM(UTC)
Replacement parts for General Electric GSD4030Z02WW Dishwasher | AppliancePartsPros.com
[COLOR="Blue"]
We leave about 3-4 cups of water start a cycle and stop real quick seems to start to drain but then water just comes back up the drain.[/COLOR]
Could you clarify the above. Are you talking about the house drain or the machine.
Here is an install sheet
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=31-30515.pdf
If installed onto a garbage disposal was the drain plug removed?
If it is water coming up into the sink you probably have a partial house plumbing plug.
To check this you could drain it into a pail. Hold the drain line securely in the pail and put a tower over it to stop it from splashing all over. Unless you want a shower.
Is the drain line looped up higher than the drain input, see the install sheet.
This prevents the unit from siphoning water back out of the drain.
Remove the sump cover (Item 506 in Section 2) and check the sump for debris and twist ties etc. wrapped around the chopper. Be careful there is often broken glass in the sump. Also take note how the inner part is installed, re-install it wrong and the chopper will eat it. Probably not a bad idea to do this anyway on a used machine.
Remove the filter (rear, bottom of the tub) and check the Piston & Nut (Item 564 in Section 2), it unscrews. If the seal on it is gone/leaking replace it, as part of the water is directed back into the tub instead of out the drain so it never drains completely. A very common problem with these units.
Note: These units usually leave about a 1/4 inch of water in the tub.
These pumps do not like to run totally dry as they can burn up the seals.
If you have to empty the sump always add a quart or so of water to the unit before re-starting.
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
by av0612 8/6/2014 4:42:36 PM(UTC)
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
