MODEL1932
#1 Posted : Tuesday, February 2, 2010 12:13:25 PM(UTC)
MODEL1932
I have a MAYTAG RANGE model MER5730AAw glasstop. The right rear element went out, so I replaced it. The new element stayed on high no matter where I set the switch. So I replaced the switch with a new one. Same result, It stays on high no matter where I set the switch. Also the
"Hot Surface Lite" goes off when I turn the switch off instead of staying on untill the surface cools. Any help with this one?
Element stays on high, Maytag Gemini (Oven Repair (including Ranges and Cooktops))
by bwwais 10/24/2010 4:20:47 PM(UTC)
