:eek: my dryer quit working,and i am trying to fix it my self.but i think it might be the motor or the belt.the tumbler will not turn it is real tight,and when you turn on the dryer it hums and wont turn.from the blueprint sheets it dont show if there is a belt and the motor is in the washer part from what it shows.if you know anything on this machine i wold like to know so i can get the right part.i just hope it is not going to be a nightmare to take apart. these stackabels are alot differnt to work on then a single dryer or washer. thanks much freddie
Here are your parts Replacement parts for FRIGIDAIRE FLXE52RBS9 Laundry Center - Frigidaire | AppliancePartsPros.comHere is a wiring diagram which may come in handy in the future http://manuals.frigidaire.com/prodinfo_pdf/Webster/131988900.pdfAnd a manual which should be close to your unit http://frigidaireservicetips.com/pdfs/488_3.pdfRun your fingers around the seals at the front and back of the drum just in case something has jammed in there. Be careful, it may be sharp. If clear You will have to open it up to find what is causing the problem. Odds are it is the rear bearing but may also be the front glides etc.. Be sure to re-lube the rear bearing using hi-temp grease. Since it is a pain to work on I would replace anything that looks worn. Be careful when removing the rear grounding ball bearing (Item 5 in Section 1). Once released it likes to take off and play hide and seek. While in there check the belt etc. Give the interior a good cleaning including a clean/check of the blower. Turn the motor manually to ensure it's bearings are OK. Also a good time to clean/check your vent system. Note: There is a possibility that the motor will have to be replaced but you will not know this till you have the drum rotating manually. |
THIS FORUM IS DEAD!!!!!!! |
