ken graham
#1 Posted : Saturday, January 30, 2010 7:39:17 AM(UTC)
ken graham
gas dryer will not heat and it will not shut off what can i do to correct it ?
kayakcrzy
#2 Posted : Sunday, January 31, 2010 6:11:23 AM(UTC)
kayakcrzy
The reason it did not shut off, was because the dryer was not heating. So there is nothing wrong with that. Unplug the dryer and take the back off. When you do you will seen a part called a thermal fuse. It is about an inch and a half long, by a half inch wide. It will have 2 wires comeing to it, and 1 screw holding it in place. It will be about a foot off the ground, just about in the middle. Take the 2 wires off of it, and put the terminal ends together, and then put a little tape around them to keep them together, and so they don't hit metal, and then plug it in, and see if it works. If it does, DO NOT RUN the dryer like that. The fuse is the only thing from burning down the house. Let me know how it goes. Tom ApplianceEducator.com - Parts
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
