marciabloem
#1 Posted : Tuesday, April 15, 2008 1:56:36 PM(UTC)
marciabloem
My dryer drum won't turn, when I push the start button it starts counting down the time but nothing happens with the drum. My hubby, Mr. Fixit himself, thinks it's the starter in the door or in the internal works, help please!:rolleyes:
bambiblaster
#2 Posted : Tuesday, April 15, 2008 4:16:24 PM(UTC)
bambiblaster
1st make sure you have 220v to the dryer... unplug move out (I usually lay them on the front).. remove rear cover... above left where the vent hose attaches are 2 wires going to the thermal fuse.. remove 1 wire and check to see if it has continuity( the fuse is about 2" long and white).. if no continuity replace and make sure vent thru house to the outside is clear
Dryer drum won't turn (Dryer Repair)
by JudyStud 6/16/2017 11:18:11 AM(UTC)
by jonenright 7/11/2013 10:14:04 AM(UTC)
Electric dryer drum won't turn (Dryer Repair)
by angola20 1/11/2013 1:27:49 PM(UTC)
Maytag Dryer Drum Won't Turn (Dryer Repair)
by ohiojt 6/10/2012 7:32:15 PM(UTC)
by paul.k.best@gmail.com 8/11/2011 6:59:00 AM(UTC)
by DB in NC 12/17/2010 6:17:30 PM(UTC)
Dryer Drum Won't Turn, But Turns On & Heats Up (Dryer Repair)
by EmilyBTown 5/24/2010 11:07:40 AM(UTC)
by soundoff 5/22/2010 10:57:36 AM(UTC)
by benabbott 1/2/2010 9:22:31 AM(UTC)
by bparks9111 3/16/2009 5:25:38 PM(UTC)
by coolrunning 4/15/2008 3:19:51 AM(UTC)
by PSINKHORN 10/28/2007 3:35:56 PM(UTC)
by tlathan 8/15/2007 10:50:22 AM(UTC)
