jonenright
#1 Posted : 11 years ago
jonenright
Sometimes when I start the dryer the drum won't turn. The motor hums and the drum can be started by giving it a spin.
HumboldtRepairMan
#2 Posted : 11 years ago
HumboldtRepairMan
Dryer motor windings or capacitor might be going bad check voltage at motor you should have (2) 120 readings at the motor one for start up and another for operation. Check motor with belt off unit and see if it works fine if so you may have a bad main bearing or rollers depending on the type of drum. If you don't get (2) 120 readings at motor suspect the main control board or maybe a shorting door switch? Check your wiring diagram and chase the trail of wiring make sure you got no shorts in the wiring also with continuity test. Good luck
Dryer drum won't turn (Dryer Repair)
by JudyStud 8 years ago
Electric dryer drum won't turn (Dryer Repair)
by angola20 12 years ago
Maytag Dryer Drum Won't Turn (Dryer Repair)
by ohiojt 13 years ago
by paul.k.best@gmail.com 13 years ago
by DB in NC 14 years ago
Dryer Drum Won't Turn, But Turns On & Heats Up (Dryer Repair)
by EmilyBTown 15 years ago
by soundoff 15 years ago
by benabbott 15 years ago
by bparks9111 16 years ago
by marciabloem 17 years ago
by coolrunning 17 years ago
by PSINKHORN 17 years ago
by tlathan 17 years ago
