benabbott
#1 Posted : 15 years ago
benabbott
The drum will not turn. When you push it start knob you can hear it try to start. I have checked the belt and there is nothing binding it. I removed the drum and bypassed the door cut-off and the motor turns fine. Put it all back together and then it won't turn again. Is there any thing I am missing? Thank you for your help.
#2 Posted : 15 years ago
Try turning the drum by hand in the correct direction, it should turn fairly easily.
I know fairly easily is not much of a description so you may want to try this on a couple other dryers to get a feel for it.
If OK
Then the probable cause is the motor not having enough power to start with a load on it. Could be that the start winding is open.
If NG
Then you will have to open it up and find what is causing it to jam re; worn front glides or a bad roller etc.
benabbott
#3 Posted : 15 years ago
benabbott
It is somewhat hard to turn. When you push it and start it at the same time it will start running. However it will not even push start with a load of laundry. Am I looking at replacing the motor?
#4 Posted : 15 years ago
Odds are high that this is the problem.
But I would check into the drum rotation more especially if with a load in it becomes very difficult to turn.
Dryer drum won't turn (Dryer Repair)
by JudyStud 8 years ago
by jonenright 12 years ago
Electric dryer drum won't turn (Dryer Repair)
by angola20 12 years ago
Maytag Dryer Drum Won't Turn (Dryer Repair)
by ohiojt 13 years ago
by paul.k.best@gmail.com 14 years ago
by DB in NC 14 years ago
Dryer Drum Won't Turn, But Turns On & Heats Up (Dryer Repair)
by EmilyBTown 15 years ago
by soundoff 15 years ago
by bparks9111 16 years ago
by marciabloem 17 years ago
by coolrunning 17 years ago
by PSINKHORN 17 years ago
by tlathan 18 years ago
