benabbott
#1 Posted : Saturday, January 2, 2010 9:22:31 AM(UTC)
benabbott
The drum will not turn. When you push it start knob you can hear it try to start. I have checked the belt and there is nothing binding it. I removed the drum and bypassed the door cut-off and the motor turns fine. Put it all back together and then it won't turn again. Is there any thing I am missing? Thank you for your help.
#2 Posted : Sunday, January 3, 2010 2:17:11 AM(UTC)
Try turning the drum by hand in the correct direction, it should turn fairly easily.
I know fairly easily is not much of a description so you may want to try this on a couple other dryers to get a feel for it.
If OK
Then the probable cause is the motor not having enough power to start with a load on it. Could be that the start winding is open.
If NG
Then you will have to open it up and find what is causing it to jam re; worn front glides or a bad roller etc.
benabbott
#3 Posted : Sunday, January 3, 2010 5:32:14 AM(UTC)
benabbott
It is somewhat hard to turn. When you push it and start it at the same time it will start running. However it will not even push start with a load of laundry. Am I looking at replacing the motor?
#4 Posted : Sunday, January 3, 2010 6:33:42 AM(UTC)
Odds are high that this is the problem.
But I would check into the drum rotation more especially if with a load in it becomes very difficult to turn.
Guest (6)
Dryer drum won't turn (Dryer Repair)
by JudyStud 6/16/2017 11:18:11 AM(UTC)
by jonenright 7/11/2013 10:14:04 AM(UTC)
Electric dryer drum won't turn (Dryer Repair)
by angola20 1/11/2013 1:27:49 PM(UTC)
Maytag Dryer Drum Won't Turn (Dryer Repair)
by ohiojt 6/10/2012 7:32:15 PM(UTC)
by paul.k.best@gmail.com 8/11/2011 6:59:00 AM(UTC)
by DB in NC 12/17/2010 6:17:30 PM(UTC)
Dryer Drum Won't Turn, But Turns On & Heats Up (Dryer Repair)
by EmilyBTown 5/24/2010 11:07:40 AM(UTC)
by soundoff 5/22/2010 10:57:36 AM(UTC)
by bparks9111 3/16/2009 5:25:38 PM(UTC)
by marciabloem 4/15/2008 1:56:36 PM(UTC)
by coolrunning 4/15/2008 3:19:51 AM(UTC)
by PSINKHORN 10/28/2007 3:35:56 PM(UTC)
by tlathan 8/15/2007 10:50:22 AM(UTC)
