Hello, I will be replacing the soap dispenser on my dishwasher and have a question. The new dispenser, AP3176640, is what I ordered and is a newer/different part than the original. (New Re-designed dispenser. Rinse Aid sensor no longer needs to attach to dispenser). Do I need to do anything special when replacing the dispensor with the sensor connection that I don't hook up anymore? Does the sensor need to be replaced with the dispenser? or is the sensor not used anymore and the new dispensor is just a plug/play part and that's all?
Looks like you may have ordered the wrong part, re: just the sensor not the dispenser Part number: AP3176640
The dispenser is Part number: AP3774956
The rinse level detection is gone guess it was causing more problems than it was worth. Just tape up the connector that went to the level sensor and tuck/tape it out of the way. |
THIS FORUM IS DEAD!!!!!!! |
Thanks for the quick reply. The problem i'm having is if I fill the soap up and close the door, the soap will start falling out by itself if i don't start it up right away. Also, the rinse agent is also running out a lot faster than normal. I figured the rubber seals where wearing out and I ordered the soap dispenser. Do I need a new rinse aid sensor as well? i was thinking not since it's not suppose to be connected the the Newer dispenser.
[COLOR="Blue"]Do I need a new rinse aid sensor as well?[/COLOR] No
[COLOR="Blue"] i was thinking not since it's not suppose to be connected the the Newer dispenser.[/COLOR] That is correct but the number you said you ordered in your first post is for the sensor not the dispenser. |
Thanks for the reply. I did'nt think i needed the sensor either.
I typed in the wrong part number in my first post. I just checked my order and I did order the correct part I needed. Dispenser. part ordered was AP3774956
Thanks again for all the help.
