dmhoot
#1 Posted : Wednesday, January 27, 2010 8:46:48 PM(UTC)
dmhoot
Hello, I will be replacing the soap dispenser on my dishwasher and have a question. The new dispenser, AP3176640, is what I ordered and is a newer/different part than the original. (New Re-designed dispenser. Rinse Aid sensor no longer needs to attach to dispenser). Do I need to do anything special when replacing the dispensor with the sensor connection that I don't hook up anymore? Does the sensor need to be replaced with the dispenser? or is the sensor not used anymore and the new dispensor is just a plug/play part and that's all?
#2 Posted : Thursday, January 28, 2010 2:55:12 AM(UTC)
Looks like you may have ordered the wrong part, re: just the sensor not the dispenser
Part number: AP3176640
The dispenser is
Part number: AP3774956
The rinse level detection is gone guess it was causing more problems than it was worth.
Just tape up the connector that went to the level sensor and tuck/tape it out of the way.
dmhoot
#3 Posted : Thursday, January 28, 2010 6:20:02 AM(UTC)
dmhoot
Thanks for the quick reply. The problem i'm having is if I fill the soap up and close the door, the soap will start falling out by itself if i don't start it up right away. Also, the rinse agent is also running out a lot faster than normal. I figured the rubber seals where wearing out and I ordered the soap dispenser. Do I need a new rinse aid sensor as well? i was thinking not since it's not suppose to be connected the the Newer dispenser.
#4 Posted : Thursday, January 28, 2010 6:25:15 AM(UTC)
[COLOR="Blue"]Do I need a new rinse aid sensor as well?[/COLOR]
No
[COLOR="Blue"] i was thinking not since it's not suppose to be connected the the Newer dispenser.[/COLOR]
That is correct but the number you said you ordered in your first post is for the sensor not the dispenser.
dmhoot
#5 Posted : Thursday, January 28, 2010 4:30:50 PM(UTC)
dmhoot
Thanks for the reply. I did'nt think i needed the sensor either.
I typed in the wrong part number in my first post. I just checked my order and I did order the correct part I needed. Dispenser. part ordered was AP3774956
Thanks again for all the help.
bosch soap dispenser replacement (Dishwasher Repair)
by AReed 10/19/2009 2:12:06 PM(UTC)
