I have a side by side fridge,Ice accumilates in botom of freezer,both fridge and freezer cool fine,defrost problem????? If anyone could help it would be appreciated
thanx: wrench
Most likely the problem is a clogged and frozen drain under the evaporator coil.
Remove the rear panel in the freezer and using a hair dryer, defrost the drain.
Remove the cover on the back of the fridge and make sure the other end of the drain hose is open.
Using a cup of hot water make sure it goes through the drain.
thank you gene,I will try that...........
