wrench
#1 Posted : Wednesday, April 9, 2008 4:03:39 PM(UTC)
wrench
I have a side by side fridge,Ice accumilates in botom of freezer,both fridge and freezer cool fine,defrost problem????? If anyone could help it would be appreciated
thanx: wrench
#2 Posted : Thursday, April 10, 2008 11:38:01 AM(UTC)
Most likely the problem is a clogged and frozen drain under the evaporator coil.
Remove the rear panel in the freezer and using a hair dryer, defrost the drain.
Remove the cover on the back of the fridge and make sure the other end of the drain hose is open.
Using a cup of hot water make sure it goes through the drain.
wrench
#3 Posted : Thursday, April 10, 2008 3:26:28 PM(UTC)
wrench
thank you gene,I will try that...........
Frost/ice in freezer (LG) (Refrigerator & Freezer Repair)
by alp16 9/6/2018 10:37:40 AM(UTC)
excessive water/ice in freezer (Refrigerator & Freezer Repair)
by john potts 3/30/2012 9:47:50 AM(UTC)
Ice in freezer section (Refrigerator & Freezer Repair)
by bobbertj 5/28/2011 9:37:03 AM(UTC)
side by side refrigerator generating lot of ice in freezer (Refrigerator & Freezer Repair)
by inqfinance 9/4/2010 7:21:04 AM(UTC)
Ice in freezer and fre no cold (Refrigerator & Freezer Repair)
by fortune1995 5/8/2009 9:27:39 AM(UTC)
Dry ice in freezer (Refrigerator & Freezer Repair)
by Savage32 10/27/2008 5:30:21 PM(UTC)
