jlrobin01
#1 Posted : Tuesday, April 8, 2008 4:34:35 PM(UTC)
jlrobin01
Kenmore dryer will not start, I have tested the thermal fuse, the thermostat, and the heating element. I have tested for 240 volts at the wall plug and the connection block in the dryer. The only thing left to test is the Timer Switch and how do you test it just because the clock works does not mean the power is making contact internally.
#2 Posted : Wednesday, April 9, 2008 2:07:25 PM(UTC)
The first thing I would check is the thermal fuse. It's located on the blower wheel cover behind the front panel.
Replace the thermal fuse if it's open.
- The part number for the thermal fuse is AP3133489
Dryer Will Not Run Unless Knob Is Held (Dryer Repair)
by Dixiedogs99 12/10/2017 5:41:06 PM(UTC)
Dryer will not run on no heat setting (Dryer Repair)
by rgarris1969 3/11/2017 6:59:15 PM(UTC)
Dryer will not run after changing plastic shims (Dryer Repair)
by Craig Lee 1/30/2017 4:09:05 AM(UTC)
Dryer Will not Run without manual turn of Drum (Dryer Repair)
by Cadman07 9/17/2015 6:58:08 AM(UTC)
Kenmore Elite Dryer will not run for more than a second...have done lots of troublesh (Dryer Repair)
by The_Wizard 11/10/2014 4:39:55 PM(UTC)
Dryer will not run (Dryer Repair)
by kaostheory09 9/7/2014 1:04:46 PM(UTC)
Dryer will not run at all. (Dryer Repair)
by Kabbybarty 1/15/2014 6:34:36 PM(UTC)
Electric Roper Dryer will not run anymore (Dryer Repair)
by twsno 6/6/2013 4:12:17 PM(UTC)
whirlpool dryer will not run !!!!! (Dryer Repair)
by onestress 3/20/2012 6:39:02 PM(UTC)
Roper Dryer will not run (Dryer Repair)
by stevel75 2/26/2012 9:03:36 AM(UTC)
Electric Dryer will not run (Dryer Repair)
by nickfuhs 12/11/2011 1:04:29 PM(UTC)
Frigidaire dryer will not run (Dryer Repair)
by jchalfant 9/17/2010 5:57:01 AM(UTC)
by paula8315 7/17/2010 6:40:32 PM(UTC)
Dryer Will Not Run (Dryer Repair)
by lamodj 7/12/2010 8:37:57 AM(UTC)
by pstulken 5/11/2010 7:06:53 AM(UTC)
