kevin madson
#1 Posted : Monday, April 7, 2008 2:15:38 PM(UTC)
kevin madson
My L-1 wire burnt up at the terminal board melting the wire completely off and the melting the terminal board. any ideas??
#2 Posted : Tuesday, April 8, 2008 12:23:27 PM(UTC)
Hi Kevin,
It was probably a loose connection at the terminal block which cause it to overheat.
Replace the terminal block and fix the burned wire. If the power cord is damaged too - replace the power cord.
- The part number for the terminal block is AP2042620
- The part number for the 5 feet power cord is AP2615176
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
