sdeacon2
#1 Posted : Thursday, January 21, 2010 2:25:31 PM(UTC)
sdeacon2
Traced no heat to faulty igniter. Replaced igniter. Test cycle, igniter glowed bright red to yellow, gas ignited. 2nd test same. 3rd cylce igniter broke apart. Igniter was new from Appliance Pros. Sensor on heat tube tests fine for continuity, would you recommend replacing sensor? Possible igniter was faulty?
sdeacon2
#2 Posted : Sunday, January 24, 2010 6:23:44 AM(UTC)
sdeacon2
installed new igniter using gloves to avoid getting skin oil on coil. All fixed. Side note; when removing igniter not necessary to remove screw, just loosen and slide igniter forward.
Dryer igniter won't glow (Dryer Repair)
by swatosh 12/29/2017 8:33:50 AM(UTC)
LG Dryer Igniter Cycles, but rarely flames and I smell Gas (Dryer Repair)
by afb2r 12/6/2017 10:47:59 AM(UTC)
GE Gas Dryer Igniter Glows but No Flame (Dryer Repair)
by kwillindy 5/4/2015 9:21:49 AM(UTC)
Dryer Igniter No Neutral? (Dryer Repair)
by fixanything 10/27/2014 5:22:56 AM(UTC)
Maytag Dryer igniter? (Dryer Repair)
by naibbian 4/24/2012 3:46:25 PM(UTC)
dryer igniter will not glow (Dryer Repair)
by hrdrockmom 3/13/2012 12:30:05 PM(UTC)
Dryer Igniter Problem? (Dryer Repair)
by Danielwolfmountain 1/23/2012 1:52:16 PM(UTC)
Amana gas dryer igniter won't glow (Dryer Repair)
by MarvinAllred 1/25/2011 5:56:10 AM(UTC)
