The small burner igniter does not work. The insulating gasket (between burner and frame) is cracked and falling apart from age. I suspect the igniter is shorting out. I would like to change out ALL (4) gaskets, large and small. It seems the large gaskets are not available. Is there a "kit" that might include all parts for this?
if you buy the "Sealed Gas Burner) do you get all hardware included? Will it include the all important gasket? AP2926815.
Jim
