Jim Y
#1 Posted : Monday, April 7, 2008 9:49:56 AM(UTC)
Jim Y
The small burner igniter does not work. The insulating gasket (between burner and frame) is cracked and falling apart from age. I suspect the igniter is shorting out.
I would like to change out ALL (4) gaskets, large and small. It seems the large gaskets are not available.
Is there a "kit" that might include all parts for this?
if you buy the "Sealed Gas Burner) do you get all hardware included? Will it include the all important gasket? AP2926815.
Jim
KitchenAid Burner Replacement (Oven Repair (including Ranges and Cooktops))
by vespa_1 12/2/2009 2:31:54 PM(UTC)
