Groups ready for retrieval: Registered
While cooking I discovered that the right rear burner was no longer heating. I replaced the pot on the left front burner which immediately became hot and continued cooking. Later when I returned it too was no longer heating. The left back burner and the right front burner continue to work.
Before I order new burners I would like to know if there could be another explanation for this problem. Should I do further checking before ordering new burners?
John Scott
THIS FORUM IS DEAD!!!!!!! |
