Acerocks
#1 Posted : Wednesday, January 20, 2010 3:44:12 AM(UTC)
Acerocks
MY problem is that I have no heat coming from my dryer. I have unplugged the thermal fuse and taped the two ends together to bypass the fuse. Still no heat. Whats next to check? Right next to the Thermal Fuse is the Thermistor could that be bad? I don't really know too much about checking with a meter since I don't have one. What makes the heat. I am capable of changing parts but want to know which ones to change I already had the Thermal Fuse coming before I checked it hoping it would be that.
Thanks in advance for any help.
#2 Posted : Wednesday, January 20, 2010 10:34:59 AM(UTC)
I cannot find info on this unit.
Hopefully you have the wiring diagram, if not check in the control console.
Often dryers have two thermal fuses. The one on the blower is for the motor. The one on the heating element case is for the heater. Could be you were looking at the wrong fuse.
Only way to check the thermistor is with a meter.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit's terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Odds are that the thermal fuse is blown.
Unplug the unit and check it with a meter, should be 0 ohms.
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the heater is OK then I would also replace the hi-limit thermostat as this should have regulated the temperature so that the fuse did not blow.
You still have to find the cause.
It could be:
A dirty/loose blower wheel
A dirty vent system or it's outside louvers are not opening.
A bad cycling (control) thermostat. Note this is a 4 connector thermostat.
One set is the contacts. The other set is the internal heater, should be around 25,000 ohms. This is used to give you different heat settings.
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Acerocks
#3 Posted : Wednesday, January 20, 2010 2:18:59 PM(UTC)
Acerocks
Ok so where is the "other" thermal fuse at? I have looked at the parts diagram on sears parts direct and don't see it.
#4 Posted : Wednesday, January 20, 2010 4:15:16 PM(UTC)
OK I went to Sears, It is Cutoff-tml Item 47 in the Bulkhead section.
Acerocks
#5 Posted : Saturday, January 23, 2010 1:27:17 PM(UTC)
Acerocks
So I did this for the coil and am getting no reading at all (Infinity) plugged in not plugged in ground on cas hot on wire no measurement at all to the coil. Everything else goes to O no problem. Coil is not sagging at all so its not touching the case. I think it just had too much lint inside the whole thing and caused it to overheat. Like I said everything else down there seemed to have continuity, thermal fuse, Cutoff tml, thermistor, and the thermostats all seemed good to me. Any ther thoughts or does it sound like the coil is bad?
#6 Posted : Wednesday, January 27, 2010 1:41:25 AM(UTC)
[COLOR="Blue"]So I did this for the coil and am getting no reading at all (Infinity) plugged in not plugged in ground on cas hot on wire no measurement at all to the coil.[/COLOR]
Not quite sure what you mean?
[COLOR="Blue"]
Any ther thoughts or does it sound like the coil is bad[/COLOR]
Does sound like the heating coil is open, it should read around 12 ohms.
Sorry for not getting back to you sooner but got stuck at the lake due to a storm.
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
Kenmore model 11060022010 electric dryer no heat (Dryer Repair)
by mike5466 5/1/2020 10:29:22 AM(UTC)
Samsung dryer no heat - 5 possible components? (Dryer Repair)
by sgsiegel 2/11/2018 7:02:33 AM(UTC)
by tombeird 11/8/2017 2:32:42 PM(UTC)
Maytag Atlantic Dryer no heat but everything tests ok (Dryer Repair)
by oldebrowndog 11/10/2015 11:38:46 AM(UTC)
Dryer No Heat.mind boggling! (Dryer Repair)
by andrelaplume 10/10/2015 7:22:06 PM(UTC)
by fhorta 9/28/2015 12:22:36 PM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
hot point dryer no heat and timer doesn't advance (Dryer Repair)
by gooseofdeuce 4/18/2015 8:29:56 AM(UTC)
by SEMIFAST0 3/15/2015 9:00:11 AM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
