rockylowe
#1 Posted : Tuesday, January 19, 2010 7:32:38 PM(UTC)
rockylowe
I have a Kenmore stackable washer/dryer and my dryer won't start. When I turn and hold the start switch I can hear the timer make a noise but the dryer won't start. Do I need a new switch or a new timer?
#2 Posted : Wednesday, January 20, 2010 3:31:17 AM(UTC)
Here are the parts. Your unit is actually a Frigidaire.
Replacement parts for KENMORE 41797802792 | AppliancePartsPros.com
Here is a manual
http://frigidaireservicetips.com/pdfs/488_3.pdf
I am guessing that this will be close to your unit but cannot confirm this.
If nothing else it will give you an idea of how Frigidaire does things.
[COLOR="Blue"]Do I need a new switch or a new timer[/COLOR]
Probably neither.
If you look at Page 14 in the manual you will see that there is a Thermal Limiter (fuse) in the motor circuit. I would check this, it should be 0 ohms at room temperature.
If it is blown be sure to check/clean your vent system. This is the most common cause of it blowing.
Also clean/check the blower wheel.
rockylowe
#3 Posted : Wednesday, January 20, 2010 4:16:14 PM(UTC)
rockylowe
Thanks,
The repair manual was a big help. I'll check it out,
thanks again.
rockylowe
#4 Posted : Saturday, January 30, 2010 8:10:46 AM(UTC)
rockylowe
Originally Posted by: rockylowe Go to Quoted Post
Thanks,
thanks again.
I installed the part and the dryer works fine
Thanks for everything
Rocky
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
