I have a Kenmore stackable washer/dryer and my dryer won't start. When I turn and hold the start switch I can hear the timer make a noise but the dryer won't start. Do I need a new switch or a new timer?
Here are the parts. Your unit is actually a Frigidaire. Replacement parts for KENMORE 41797802792 | AppliancePartsPros.comHere is a manual http://frigidaireservicetips.com/pdfs/488_3.pdfI am guessing that this will be close to your unit but cannot confirm this. If nothing else it will give you an idea of how Frigidaire does things. [COLOR="Blue"]Do I need a new switch or a new timer[/COLOR] Probably neither. If you look at Page 14 in the manual you will see that there is a Thermal Limiter (fuse) in the motor circuit. I would check this, it should be 0 ohms at room temperature. If it is blown be sure to check/clean your vent system. This is the most common cause of it blowing. Also clean/check the blower wheel. |
THIS FORUM IS DEAD!!!!!!! |
Thanks, The repair manual was a big help. I'll check it out, thanks again.
Originally Posted by: rockylowe ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thanks, The repair manual was a big help. I'll check it out, thanks again. I installed the part and the dryer works fine Thanks for everything Rocky
