florida
#1 Posted : Monday, January 18, 2010 4:11:11 PM(UTC)
florida
The motor won't run. Test shows motor low current. Motor windings show ok. Which would be the most possable: the washer control electronic card or the thermsistor?
#2 Posted : Tuesday, January 19, 2010 12:29:51 AM(UTC)
Here are your parts includes the wiring diagram
Replacement parts for MAYTAG MDB7130AWW Dishwasher - Undercounter | AppliancePartsPros.com
I cannot find technical info on this unit.
[COLOR="Blue"]
The motor won't run. Test shows motor low current. Motor windings show ok.[/COLOR]
I am assuming you checked the windings with a meter.
[COLOR="Blue"]Which would be the most possable: the washer control electronic card or the thermsistor?[/COLOR]
The thermistor should not effect the motor, it is just temperature sensing.
Could be the control board or the motor.
I am assuming that you have checked the motor and it rotates freely.
I would do a live test.
If the wash and main windings are getting 120 volts when they should then the motor is the probable cause.
Just be very very careful. 120 volts shouldn't kill you but when you yank your hand back odds are you will loose some skin !!
Also I have you checked the winding's resistance to it's case.
It is possible that one of them has shorted to the case and this blew the board.
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
MAYTAG MVWB725BW0 ISSUE (Washer Repair)
by jim hull 6/24/2024 6:25:14 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Older Maytag won't run (Washer Repair)
by PatAMcD 6/6/2024 12:39:06 PM(UTC)
Maytag vibration after new suspension (Washer Repair)
by Poprox0013 6/5/2024 9:49:34 PM(UTC)
maytag maxima mhw6000aw0 (Washer Repair)
by Guest 5/28/2024 6:30:55 AM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Maytag DE313 Auto Dry malfunction (Dryer Repair)
by DeanEyford 5/5/2024 11:42:21 AM(UTC)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag throws unbalanced code but spins fine in Drain and Spin mode (Washer Repair)
by Guest 5/3/2024 3:49:04 AM(UTC)
Maytag atlantis half works (Dryer Repair)
by BDR1783 5/3/2024 1:04:26 AM(UTC)
Maytage PYE3300AYW: can't seat drum on new wheels (Dryer Repair)
by Guest 4/26/2024 3:05:06 PM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Maytag Light (Dishwasher Repair)
by Rleblanc 4/22/2024 8:47:19 AM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
