I replaced the solenoid for the water fill;it run one cycle and made four ice cubes and that was that . any suggestions?
Did you check the water filter and the water feeding tube into the ice maker?
The model number you posted is incorrect. Verify and repost it, please.
Gene, The model # that I got from the refrigerator is frs26zshb2 and it belong to a frigidaire gallery with a s# laoo314119 . The numbers on the ice maker are SA 8868, 011800. Like I mention in my first post I replaced the fill solenoid and it made a small amount of ice one time and that was that. I would appreciate your help.
How is the water dispenser works?
Did you check the water filter for age and condition? It could be old or frozen.
