Hello all... Im new to the forum and a first timer on the do it yourself repair on my Kenmore 90 series washer. I replaced the coupler and agitator dogs today and that solved the issue with no-spinning and grinding noise and the agitator not moving.. New issue... When it gets to the the area just before the 1st rinse cycle it just drains the water and wont spin but you hear the motor buzzing... I just turned the washer off and then back on and it spins and drains the water like normal, and continues the rest of the wash fine. Its just that first rinse cycle that i have to turn it off and then on to get it to finish.. Any clues? HELP PLEASE!!!!!!!!
Also... wanna make sure I explained this thoroughly... The part the cycle that is having issue and when it spins and drains the water for the first time... thats the problem area.. It will drain water but wont spin... but when i turn the washer off and back on, bingo!!! ... everything works fine from that point until the wash completes
