djones
#1 Posted : Wednesday, January 13, 2010 4:35:30 PM(UTC)
djones
The control panel does not respond when the buttons are pressed. I have replaced the control panel and the door latch assy. None of the lights on the control panel work except when I lock the panel. Only the lock light comes on. I have checked for voltage at the panel and I have 120 V.
John @ Fischers
#2 Posted : Wednesday, January 13, 2010 4:39:09 PM(UTC)
John @ Fischers
Make and model. How old is it?
What was the original problem?
djones
#3 Posted : Wednesday, January 13, 2010 4:43:55 PM(UTC)
djones
Maytag Dishwasher M/N MDBTT50AWS. Original problem: Dishwasher would not do anything. No lights at control panel.
#4 Posted : Wednesday, January 13, 2010 10:40:42 PM(UTC)
Sounds like the control lock (out) has been turned on by mistake.
Here is the operators manual, check out page 7.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%206920187.pdf
Not sure of the history of this but if this was also your original problem, it could be that the heated dry button is shorted. See the following data sheet and check it with a meter.
http://www.servicematters.com/docs/wiring/TechSheets_11_17_09/Schematic%20-%20W10111827.pdf
djones
#5 Posted : Thursday, January 14, 2010 7:59:41 AM(UTC)
djones
Thanks,
I replaced the control board and had the same problem. Does the control board come locked out. If so how do you unlock it. I tried doing it with the manual and it would lock and unlock.
David V. Jones
#6 Posted : Thursday, January 14, 2010 9:19:52 AM(UTC)
[COLOR="Blue"]I replaced the control board and had the same problem.[/COLOR]
Did the original board let you lock/unlock the keypad or was it totally dead?
[COLOR="Blue"]Does the control board come locked out.[/COLOR]
No
[COLOR="Blue"]I tried doing it with the manual and it would lock and unlock.[/COLOR]
Sounds like this is working so you know the board is getting power.
Try running the diagnostics.
If no joy check the keypad switches using the tech sheet info.
djones
#7 Posted : Thursday, January 14, 2010 11:03:08 AM(UTC)
djones
I did not try to lock out the old board. The complaint was no response with the control panel.
Do you have a link to download the diag and the tech data sheet?
Thanks,
David V. Jones
#8 Posted : Thursday, January 14, 2010 11:53:29 AM(UTC)
Yes it was in my first post but at the bottom so did not show up too good
http://www.servicematters.com/d...atic%20-%20W10111827.pdf
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
Maytag dishwasher drain always runs? (Dishwasher Repair)
by Guest 12/15/2023 6:04:35 PM(UTC)
Heating element won't turn off on Maytag dishwasher (Dishwasher Repair)
by Guest 8/2/2023 6:10:10 AM(UTC)
Maytag dishwasher not cleaning top shelf very well. (Dishwasher Repair)
by Guest 10/20/2022 10:23:08 AM(UTC)
Maytag dishwasher leak from bottom of door (Dishwasher Repair)
by Guest 7/27/2022 1:58:00 PM(UTC)
Maytag dishwasher, cancel button (Dishwasher Repair)
by jtt21 6/28/2022 5:24:58 PM(UTC)
Maytag dishwasher quiet series 300 (Dishwasher Repair)
by Guest 6/12/2022 7:04:36 PM(UTC)
Maytag Dishwasher Not Entering Installation Cycle (Dishwasher Repair)
by Sparky9680 5/16/2022 9:37:56 AM(UTC)
Maytag dishwasher MDB4709AWW1 (Dishwasher Repair)
by dkmc1953 3/6/2022 1:13:12 PM(UTC)
Maytag Dishwasher stops several times during normal cycle (Dishwasher Repair)
by vanordens3 12/28/2021 12:26:19 PM(UTC)
Maytag Dishwasher Making Clanging Noise Even When Empty (Dishwasher Repair)
by gtg931 12/20/2021 7:13:20 PM(UTC)
Maytag dishwasher leaking and smoking (Dishwasher Repair)
by Guest 10/19/2021 2:58:51 PM(UTC)
Maytag dishwasher MDB4949SDZ0 (Dishwasher Repair)
by tonygm 5/29/2021 1:47:18 PM(UTC)
Maytag Dishwasher LEAKING underneath (Dishwasher Repair)
by bakerid2000 9/5/2019 5:49:20 PM(UTC)
Maytag dishwasher fills, then drains (Dishwasher Repair)
by vtfireman85 3/12/2019 7:30:34 PM(UTC)
