The control panel does not respond when the buttons are pressed. I have replaced the control panel and the door latch assy. None of the lights on the control panel work except when I lock the panel. Only the lock light comes on. I have checked for voltage at the panel and I have 120 V. Thanks
Make and model. How old is it?
What was the original problem?
Maytag Dishwasher M/N MDBTT50AWS. Original problem: Dishwasher would not do anything. No lights at control panel.
THIS FORUM IS DEAD!!!!!!! |
Thanks, I replaced the control board and had the same problem. Does the control board come locked out. If so how do you unlock it. I tried doing it with the manual and it would lock and unlock. David V. Jones
[COLOR="Blue"]I replaced the control board and had the same problem.[/COLOR] Did the original board let you lock/unlock the keypad or was it totally dead?
[COLOR="Blue"]Does the control board come locked out.[/COLOR] No
[COLOR="Blue"]I tried doing it with the manual and it would lock and unlock.[/COLOR] Sounds like this is working so you know the board is getting power. Try running the diagnostics. If no joy check the keypad switches using the tech sheet info. |
I did not try to lock out the old board. The complaint was no response with the control panel.
Do you have a link to download the diag and the tech data sheet? Maytag Dishwasher M/N MDBTT50AWS
Thanks, David V. Jones
