deadeye
#1 Posted : Saturday, March 29, 2008 4:33:23 PM(UTC)
deadeye
My washer dosent always spinout at hi speed or it will not spin at all. If i move the drum with may hand and then put it on spin it will spin but not always at hi speed. I was guessing the brake but i couldnot find a post for my model to confirm this . Thanks
#2 Posted : Sunday, March 30, 2008 3:05:44 AM(UTC)
Shine a lite in the spin basket and look for something stuck in the tub. If ok
pull off the outer panel, remove the pump and motor and turn the tranny coupler clockwise till the spin basket starts to turn. If hard to turn with thumb and forefinger, you either have a busted filter under the tub, or dragging brake shoes. If bad shoes, check my brake shoe replacement article on page 3 of general talk section. Post results.
deadeye
#3 Posted : Friday, April 4, 2008 6:56:09 PM(UTC)
deadeye
I dont see the filter on the part list,to see what it looks like is this a lint filter, iam planing on working on the on sat. Just wanted to have a good picture of what iam looking for . Thanks for the info.
#4 Posted : Friday, April 4, 2008 8:56:52 PM(UTC)
The filter is stuck to the bottom of the spin basket, a plastic comb shaped assembly that collects the lint and dumps it out on spin out. Sometimes they break and jam the bottom of the tub. You will need to pull the basket out to check.
bambiblaster
#5 Posted : Saturday, April 5, 2008 5:54:00 PM(UTC)
bambiblaster
Rank:: Advanced Member
Tip washer back... look on the left and right sides about 6 inches up do you see oil.. if so need gearcase and clutch
