My dryer was running fine, but after I finished a cycle & tried to start another one, it wont start. When I put it on the timer, the timer will actually move and stop when it is supposed to, but the drum dosen't go around, & it never heats up. what could my problem be? Can someone please help:confused:
I cannot get your model number to come up, so I will give you somewhat of a generic answer.
The top should come off by taking out screws inside the upper door jam. You can now check to see if the belt is broken. A broken belt would cause your symptoms, as the machine may have a broken belt switch which does not allow it to come on if the belt if broken (for safety reasons).
If this is not the problem, check you model number and post back with what you found when you took the top off.
