VKBUTANI
#1 Posted : Sunday, January 10, 2010 3:15:52 PM(UTC)
VKBUTANI
My dryer was running fine, but after I finished a cycle & tried to start another one, it wont start. When I put it on the timer, the timer will actually move and stop when it is supposed to, but the drum dosen't go around, & it never heats up. what could my problem be? Can someone please help:confused:
sidfink43
#2 Posted : Wednesday, January 13, 2010 6:22:59 AM(UTC)
sidfink43
I cannot get your model number to come up, so I will give you somewhat of a generic answer.
The top should come off by taking out screws inside the upper door jam. You can now check to see if the belt is broken. A broken belt would cause your symptoms, as the machine may have a broken belt switch which does not allow it to come on if the belt if broken (for safety reasons).
If this is not the problem, check you model number and post back with what you found when you took the top off.
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Elite Electric Dryer not working (Dryer Repair)
by Guest 7/24/2022 7:10:35 AM(UTC)
GE Dryer Not Working (Dryer Repair)
by DWMarsh 4/14/2020 2:43:03 PM(UTC)
Gas dryer not working properly after power outage (Dryer Repair)
by Frazierfam5 3/7/2016 4:43:32 PM(UTC)
by Cynthia Sosa 9/25/2015 7:00:01 AM(UTC)
Maytag Bravos Electric dryer not working after Power failure (Dryer Repair)
by JohannesB 6/29/2015 3:16:19 AM(UTC)
by cubbiesbp 3/11/2015 1:02:55 PM(UTC)
dryer not working on timed cycle (Dryer Repair)
by kwikk4 2/23/2015 7:53:40 AM(UTC)
Dryer not working properly (Dryer Repair)
by gdmcc1955 8/5/2014 9:59:33 AM(UTC)
by Vitocar 6/17/2014 11:12:39 AM(UTC)
dryer not working (surprise!) (Dryer Repair)
by thebrokenwhirlpool 3/8/2014 11:26:54 AM(UTC)
Dryer not working right (Dryer Repair)
by Monsters 10/1/2013 6:59:17 PM(UTC)
Kenmore dryer not working (Dryer Repair)
by JuanY 5/21/2013 8:57:38 AM(UTC)
Roper dryer not working in auto sense mode. (Dryer Repair)
by CWeasel 7/15/2012 10:03:37 AM(UTC)
by redrider65 2/20/2012 1:25:39 PM(UTC)
