Our electric range control panel appeared to be bad, there was no display. Replaced it today and now it only comes on if 2 burners are on. I set the time and turned the bake feature on when pre-heat was done I opened door and the display went black, then this clicking noise started. The display panel started to flash. Stove came with the house so I don't know the history. If it isn't the control panel what else could it be? correction on model # It is rf386pxgb0 Model rf386pxgb0
whirlpool super capacity 465
