HET
#1 Posted : Thursday, April 9, 2009 7:00:19 PM(UTC)
HET
Help oven won’t light
I have a Whirlpool Super Capacity 465, model # SF325PEEQ0
Turn the oven on by setting the temp to and pressing start. I hear a click from behind the control panel. The top of the oven say Pre-Heat. With temp showing. No error messages.
Below the oven does not light, no spark, glow, no nothing.
The burners on top work find.
Any ideas???
Thanks for the help!
HET
#2 Posted : Thursday, April 9, 2009 7:22:27 PM(UTC)
HET
Update:
Removed the bottom and frame spreader.
I tapped the oven burner and I see a spark.
I tried tapping the value assembly and nothing happens????
Help
#3 Posted : Friday, April 10, 2009 8:06:38 PM(UTC)
The problem is a bad oven igniter. No doubt about it.
- The part number for the igniter is AP3104565
Here are the break down diagrams and Replacement parts for WHIRLPOOL SF325PEEQ0 | AppliancePartsPros.com
- All 465 models: Whirlpool 465 parts
kbeiii
#4 Posted : Thursday, September 8, 2011 4:31:03 PM(UTC)
kbeiii
Hello,
I have a super capacity 465 (SF367LEMB 1)
Everything works, except the oven (bottom burner inside, broiler works, stove works, ie, everything else)
I've read many of these threads and as a result, replaced the ignitor, still no luck.
I'll keep searching the site in the meantime.
Any help is appreciated.
