Help oven won’t lightI have a Whirlpool Super Capacity 465, model # SF325PEEQ0Turn the oven on by setting the temp to and pressing start. I hear a click from behind the control panel. The top of the oven say Pre-Heat. With temp showing. No error messages. Below the oven does not light, no spark, glow, no nothing. The burners on top work find.Any ideas???Thanks for the help!
Update: Removed the bottom and frame spreader. I tapped the oven burner and I see a spark. I tried tapping the value assembly and nothing happens???? Help
Hello,
I have a super capacity 465 (SF367LEMB 1)
Everything works, except the oven (bottom burner inside, broiler works, stove works, ie, everything else)
I've read many of these threads and as a result, replaced the ignitor, still no luck.
I'll keep searching the site in the meantime.
Any help is appreciated.
