My dryer rotayes but it does not dry the clothes
Originally Posted by: brandiesgran ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My dryer rotayes but it does not dry the clothes I have a maytag dryer and when I put my clothes in it will go thru the dry cycle when it ends the clothes are still wt
To dry the clothes you need heat and air flow.
If the dryer is heating up it is an air flow problem. The most common cause of this is a clogged vent system.
Undo the dryer from the exhaust Run a load If the load dries correctly then you have a vent problem. Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house. Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust. Leave enough room behind the dryer so it can blow out like a windsock. Run a load.
Both the above will allow you to check the air flow and temp. Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems. |
THIS FORUM IS DEAD!!!!!!! |
