brandiesgran
#1 Posted : Saturday, January 9, 2010 2:18:57 PM(UTC)
brandiesgran
My dryer rotayes but it does not dry the clothes
brandiesgran
#2 Posted : Saturday, January 9, 2010 2:23:20 PM(UTC)
brandiesgran
I have a maytag dryer and when I put my clothes in it will go thru the dry cycle when it ends the clothes are still wt
#3 Posted : Sunday, January 10, 2010 6:12:43 AM(UTC)
To dry the clothes you need heat and air flow.
If the dryer is heating up it is an air flow problem. The most common cause of this is a clogged vent system.
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems.
Dryer does not dry with vent tube connected to the wall (Dryer Repair)
by kaseyh 8/27/2012 7:15:29 AM(UTC)
Dryer Does Not Dry (Dryer Repair)
by ann1@twlakes. net 7/28/2012 6:36:30 AM(UTC)
Dryer does not dry the clothes (Dryer Repair)
by Unidencku 3/12/2012 6:13:31 PM(UTC)
Dryer Does Not Dry Very Good (Dryer Repair)
by powellalex 4/1/2010 10:50:28 AM(UTC)
GE Dryer does not dry (Dryer Repair)
by pabaholic 1/27/2010 5:56:16 PM(UTC)
Dryer does not dry in washer dryer (Dryer Repair)
by larryn 12/12/2009 8:02:31 AM(UTC)
