tjl1954
#1 Posted : Saturday, January 9, 2010 5:45:35 AM(UTC)
tjl1954
Replaced heating element but cannot clear the flashing clean light.
tjl1954
#2 Posted : Saturday, January 9, 2010 5:48:29 AM(UTC)
tjl1954
Originally Posted by: tjl1954 Go to Quoted Post
Replaced heating element on my Whirlpool Dishwasher Model No. DU1055XTPQ4 but cannot clear the flashing clean light.Is there a code?]
#3 Posted : Saturday, January 9, 2010 10:12:15 AM(UTC)
Try this
Heated Dry Normal Heated Dry Normal
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
tjl1954
#4 Posted : Sunday, January 10, 2010 10:28:05 AM(UTC)
tjl1954
To Denman,
I tried your solution to my problem and it did not work.Is there a sequence that I should be using?
#5 Posted : Sunday, January 10, 2010 12:02:52 PM(UTC)
As far as I know you just follow the sequence i the data sheet.
You cold try removing power from the unit for half an hour or so to see if that may reset it.
If that does not work then perhaps the board is blown,
Did you check the original heater with a meter before replacing it?
Did you check the hi-limit thermostat?
tjl1954
#6 Posted : Sunday, January 10, 2010 12:17:39 PM(UTC)
tjl1954
Thank You denman,I was not following the right sequence.The dishwasher is operating.
Viking dishwasher repair (Dishwasher Repair)
by AngelaH 8/29/2023 8:48:21 AM(UTC)
Dishwasher Repair for GE profile (Dishwasher Repair)
by Guest 12/10/2022 11:15:25 AM(UTC)
Appliances Repair North York || Dishwasher Repair (Refrigerator & Freezer Repair)
by digitallab 7/8/2021 8:45:33 AM(UTC)
Bosch Dishwasher Repair Advice (Dishwasher Repair)
by Donan 9/20/2020 10:03:22 AM(UTC)
Samsung dishwasher repair (Dishwasher Repair)
by Cougar6069 5/5/2020 6:01:38 PM(UTC)
Dishwasher repair - kitchenaid briva KIDS36EPSS0 (Dishwasher Repair)
by magicmarc 1/8/2020 5:56:50 AM(UTC)
Bosch SHU9915UC/U11 Dishwasher repair (Dishwasher Repair)
by Yariet 11/4/2019 6:35:40 AM(UTC)
Bosch dishwasher repair (Dishwasher Repair)
by 66FSTbck 10/13/2018 7:34:04 AM(UTC)
Portable Dishwasher Repair (Dishwasher Repair)
by cliff10 1/7/2018 8:53:54 AM(UTC)
by maytagman17 9/26/2015 11:33:06 AM(UTC)
Dishwasher Repair - No water (Dishwasher Repair)
by maytagman17 9/26/2015 11:25:01 AM(UTC)
Whirlpool dishwasher repair question (Dishwasher Repair)
by asouth 1/18/2014 12:36:20 PM(UTC)
by sun47me 11/27/2013 4:46:52 PM(UTC)
Dishwasher repair.. (Dishwasher Repair)
by mssorcha51 9/11/2013 1:30:07 PM(UTC)
Bosch dishwasher repair help (Dishwasher Repair)
by jeanettekoster 10/30/2012 1:58:10 PM(UTC)
