The unit is cooling, But thermastat numbers blink to zero and turn off. Then turn on to 5 only. It has shut down now. What can I do?
Quote:...But thermastat numbers blink to zero and turn off... What does turn off: the display(s) or the whole refrigerator? Gene.
The whole refrigerator turns off!
at first it was blinking on and off and now nothing.
Sorry for the delay. Most likely the problem is a bad main control board (on the back of the refrigerator) but there is a small chance for the temperature control board to be bad as well. I would replace the main control board first. - The main control board Part number: AP4436216
We have power to the unit but display numbers are off and will not cool
