teemboo
#1 Posted : Tuesday, May 13, 2008 5:09:05 PM(UTC)
teemboo
My GE has been acting up lately. Initially it stopped working for a few hours (seemingly like it was overheated) After a short period of unplug it seemed to work fine for a few days. However, since them it has started making strange squeaky type noises seemingly from the lower right side. I removed it from the wall, removed the outer cover, turned it on, half expecting a bad fan. UNfortunately the fan itself (plastic) spins freely on or off. It is hard to pinpoint the noise to any specific part. I do not believe it is the fan motor, but cant figure if it is the large (capacitor) type box mounted to the bottom or one of the two silver boxes mounted above with a couple wires coming out of them. Is there any test that I can do to determine my issue? Any advice or guidance would be greatly appreciated.
#2 Posted : Wednesday, May 14, 2008 2:21:44 PM(UTC)
Does it heat? What is the complete model number of the microwave?
teemboo
#3 Posted : Thursday, May 15, 2008 12:58:46 PM(UTC)
teemboo
It appears to have no problem heating so far.
teemboo
#4 Posted : Thursday, May 15, 2008 1:04:17 PM(UTC)
teemboo
MOdel # is JVM1851SH06 Manufactured in October 2005. We got it installed in February 2006.
#5 Posted : Thursday, May 15, 2008 1:14:36 PM(UTC)
It is very hard (almost not possible) do diagnose such noise issue, especially if there is no heating problem. Guessing is not a way to fix anything. I would wait until it will stop heating.
abadfish66
#6 Posted : Wednesday, May 28, 2008 10:51:48 PM(UTC)
abadfish66
You need a new fan blade. What is happening is the Blade is not secure on the shaft of the fan, so it spins freely. the fan motor is turning normal, but because of the slippage of the blade, you get that squeek noise. The other thing that is happening is because the blade is slipping it is not moving very much air to keep the magnetron cool, so it is tripping the thermal overload on the magnetron, it is a self resetting tco that is why the power will come back on after it has cooled down, and kill the power when it has over heated. Should'nt cost you more than about $10 for the fan blade...Keep us posted.........
pyeman
#7 Posted : Thursday, June 19, 2008 4:21:11 PM(UTC)
pyeman
I have the van and I'm ready to replace the old one. How do I can the front panel off?
#8 Posted : Thursday, June 19, 2008 4:38:41 PM(UTC)
cso555
#9 Posted : Wednesday, October 29, 2008 2:28:30 PM(UTC)
cso555
My spacemaker does not heat anymore, it comes on and everything but no heat.
#10 Posted : Wednesday, October 29, 2008 4:35:52 PM(UTC)
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...pacemaker-xl-1800-a.html
