jmajda12
#1 Posted : Wednesday, August 15, 2007 10:34:45 AM(UTC)
jmajda12
I am currently in the Navy over in Italy and trying to repair an GE smooth top oven for our work space. It was donated and trying to get it to work and here is the issue. The clock and control will not come on. The burners still work but not the control. When we got it someone had taken the control off so i put it back together with the diagram supplied but not sure if it is right. When i open the oven door it pops the breaker, so i disoconnected the light and that fixed the popping the breaker issue. The oven control still will not come on. Can someone help with what wire go where so i can make sure i have them hooked up correctly. Then give me some options to check.
Adam / APP Team
#2 Posted : Wednesday, August 15, 2007 3:19:55 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
Dear jmajda12,
I was unable to find a wire diagram on your model and to be honest it sounds to be more involved to advise without being there.
GE Oven Control board locking after starting oven. Model # CGS985SETASS (Oven Repair (including Ranges and Cooktops))
by Mike I 1/15/2024 10:55:45 PM(UTC)
GE Oven Control Board (Oven Repair (including Ranges and Cooktops))
by BillDiesel 12/5/2017 7:36:41 AM(UTC)
GE Oven Control not working (Oven Repair (including Ranges and Cooktops))
by Timbotide 3/3/2014 11:35:24 AM(UTC)
Ge Oven Control Panel Change Out (Oven Repair (including Ranges and Cooktops))
by schrambo2001 11/20/2012 3:48:14 AM(UTC)
GE oven control (Oven Repair (including Ranges and Cooktops))
by Norman G. 11/26/2011 10:13:13 AM(UTC)
GE Oven controls don't respond (Oven Repair (including Ranges and Cooktops))
by JJJJ 10/6/2010 9:19:55 AM(UTC)
Alternative part for GE Oven Control Panel (Oven Repair (including Ranges and Cooktops))
by aoster3 5/27/2009 3:45:37 PM(UTC)
GE Oven control module (Oven Repair (including Ranges and Cooktops))
by liuguang 9/3/2008 8:07:24 AM(UTC)
GE oven control board (Oven Repair (including Ranges and Cooktops))
by larry ryan 7/19/2008 6:15:02 AM(UTC)
GE Oven Controller Board Replacement (Oven Repair (including Ranges and Cooktops))
by smtowne@cox.net 4/10/2008 6:15:36 PM(UTC)
Please help me identify this GE Oven Control Board! (Oven Repair (including Ranges and Cooktops))
by PHRoberts 2/13/2008 8:16:56 PM(UTC)
Trying to wire up GE oven control WB27T10190 (Oven Repair (including Ranges and Cooktops))
by Mr. Pogi 11/20/2007 11:38:12 AM(UTC)
GE oven control module (Oven Repair (including Ranges and Cooktops))
by droper 10/14/2007 4:45:53 PM(UTC)
