Mick McGuiness
#1 Posted : Monday, January 4, 2010 3:07:28 PM(UTC)
Mick McGuiness
Dishwasher sometimes fills with water and works just fine..other times no mater where I set the timer it the motor runs but the water does not fill entirely. I checked the water selnoid and it opens as it should.
Just as an added not..the selnoid is an 120volts AC ...when I used my voltmeter and turned the timer to the on position..sometime the voltage would read 16-18 volts...is this normal?
Any ideas???
Mick
Mick McGuiness
#2 Posted : Monday, January 4, 2010 3:35:52 PM(UTC)
Mick McGuiness
Just turned the timer to normal wash and the motor ran for 10-15 mins then the water came on...is this normal?
Mick
#3 Posted : Tuesday, January 5, 2010 5:06:49 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208563494.pdf
No but it is probably just ghost voltage so i would read it as 0 volts
Possibly no, depends where in the cycle you are re: at this point should the unit be calling for water.
I would check/clean the float assembly and check it's switch.
Could be it is intermittent and is holding the water valve off.
Also could be a set of dirty/pitted contacts in the timer.
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 4/2/2023 9:08:51 AM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 11/29/2021 2:45:31 PM(UTC)
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 11/20/2021 12:39:21 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Maytag Washer - no water (Washer Repair)
by maalfunction 11/2/2021 6:52:56 AM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 5/31/2021 10:19:02 AM(UTC)
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 1/11/2021 2:18:45 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
