mick100
#1 Posted : Wednesday, August 15, 2007 8:23:04 AM(UTC)
mick100
upper over is ok, lower oven wont ignite, igniter works, but gas will not flow,
should i be looking at a gas valve?
Admin / APP Team
#2 Posted : Friday, August 17, 2007 7:14:54 AM(UTC)
Admin / APP Team
Rank: Administration
Groups:
There is a small chance that the valve is bad, but most likely what you need to replace is the oven igniter.
- Lower oven igniter for Caloric RSS399
jomo
#3 Posted : Sunday, August 26, 2007 8:46:24 AM(UTC)
jomo
my oven will not stay on after it reaches the set temperature. I just replaced the oven igniter. What might be the problem?
Admin / APP Team
#4 Posted : Monday, August 27, 2007 8:10:46 AM(UTC)
Admin / APP Team
Groups:
jomo, it would be better if you create a new topic (click on POST NEW TOPIC) and include your oven model number.
Oven wont ignite (Oven Repair (including Ranges and Cooktops))
by mjpokor 7/16/2013 8:58:40 AM(UTC)
oven wont ignite (Oven Repair (including Ranges and Cooktops))
by Ricardo25 9/3/2012 6:42:52 PM(UTC)
oven wont ignite after replacing ignitor (Oven Repair (including Ranges and Cooktops))
by tim3768 8/14/2012 2:42:06 PM(UTC)
by tech2tech 6/12/2011 6:08:54 PM(UTC)
KitchenAid Gas Oven Wont Ignite (Oven Repair (including Ranges and Cooktops))
by traveller 4/14/2011 2:51:06 PM(UTC)
gas oven wont ignite (Oven Repair (including Ranges and Cooktops))
by wkvien 1/28/2011 12:36:55 PM(UTC)
My oven wont ignite after I tightened gas leaking connector (Oven Repair (including Ranges and Cooktops))
by raminla 6/2/2010 12:14:35 PM(UTC)
Lower part of oven wont ignite (Oven Repair (including Ranges and Cooktops))
by rdanigel 8/3/2009 4:05:57 PM(UTC)
Oven wont ignite/no gas (Oven Repair (including Ranges and Cooktops))
by pavel 2/23/2008 8:07:38 AM(UTC)
by carynlee64 2/21/2008 5:58:36 PM(UTC)
