upper over is ok, lower oven wont ignite, igniter works, but gas will not flow, should i be looking at a gas valve?
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
my oven will not stay on after it reaches the set temperature. I just replaced the oven igniter. What might be the problem?
jomo, it would be better if you create a new topic (click on POST NEW TOPIC) and include your oven model number.
