Terry Riser
#1 Posted : Wednesday, March 19, 2008 10:39:00 AM(UTC)
Terry Riser
My washer would not spin unless I pushed the knob to one side or the other. Everything else woked fine. I ordered a new timer and veryfied it was the correct one when it came. It was the right one and I put it on. I pluged it in and seemed to be fine. I put in clothes and went upstairs back to work. About a half hour later I heard water running and came down to find my basement flooded. The timer never moved from 8 which is what I set it on. The washer never stopped filling up. As I mentined before everything worked fine except the spin cycle before I put this timer on. Do I have a defective timer or what?
Matt S
#2 Posted : Wednesday, March 19, 2008 12:34:05 PM(UTC)
Matt S
No, the timer does not affect the fill level of the machine.
I would bet the water level switch pressure hose came off when you pulled the console to replace the timer.
Lift the console again and check the clear hose going to the water level switch. I bet that is pulled off. :)
Matt
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
