DonL
#1 Posted : Friday, December 18, 2009 12:32:44 PM(UTC)
DonL
My refrigerator/freezer is not cooling. I cleaned the condenser coils, which has worked in the past, but didn't help this time. I listened, and heard clicking on the #801 main board when I adjust the temperature controls for the fridge and freezer. How do I tell if the compressor is running? Should it be making a low humming noise? What would be the next troubleshooting steps?
Thank you in advance for your help!
woodchuckie
#2 Posted : Saturday, December 19, 2009 7:46:57 AM(UTC)
woodchuckie
Gain access to the compressor by removing the cardboard backing on the unit. You will be able to fill a vibration when you touch it if it's running. The coils near there should be warm. . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
double side GE fridge and freezer warm on the top (Refrigerator & Freezer Repair)
by iustina 11/18/2009 7:26:58 AM(UTC)
