Ice maker not working. Replaced motor and now water just runs into tray and then into freezer.
Which motor did you replace?
What is the complete model number of the refrigerator?
Does water run non-stop?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Which motor did you replace?
Gene. I repalced the module in front of ice maker with new one from app. Model 106- 9751723 Water does not seem to run non-stop.
There is a switch inside the ice maker head which operates with the water valve. You may want to double check the part installation.
